NM-HDV farm
smvasagam
Hi, I have installed 2 NM-HDV with 5 PVDM-12 to each on 3725. I wonder if this is normal (I try on all 12.4 IVS IOSes and all the same behavior):
When the 3725 boot up, it will show "changed state to up" for DSP 1-10 when I have 5 PVDMs, 4-15 when I have 4 PVDMs, 7-15 when I have 3 PVDMs.
The question is why the booting never show all 15 DSPs in the 5 PVDMs (just 1-10)? This happens to both of my NM-HDVs, so unless both NM-HDVs are defective, they should not behave the same way, or maybe my 3725 cannot handle all the DSPs there?
Anyone have the same experience?
When I have a show diag, I do see all the HDV SIMMs listed:
Slot 1:
High Density Voice Port adapter
Port adapter is analyzed
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware Revision : 1.1
Top Assy. Part Number : 800-03567-01
Board Revision : G0
Deviation Number : 0-0
Fab Version : 02
PCB Serial Number : JAB05400BWQ
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Product (FRU) Number : NM-HDV=
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF 40 00 CC 41 01 01 C0 46 03 20 00 0D EF 01
0x10: 42 47 30 80 00 00 00 00 02 02 C1 8B 4A 41 42 30
0x20: 35 34 30 30 42 57 51 03 00 81 00 00 00 00 04 00
0x30: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
HDV SIMMs: Product (FRU) Number: PVDM-12=
SIMM slot 0: PVDM-12 SIMM present.
SIMM slot 1: PVDM-12 SIMM present.
SIMM slot 2: PVDM-12 SIMM present.
SIMM slot 3: PVDM-12 SIMM present.
SIMM slot 4: Empty.
HDV firmware: Compiled Fri 19-Nov-04 14:23 by michen
HDV memory size 524280 heap free 193977
Slot 2:
Board Revision : H0
Fab Version : 02
PCB Serial Number : JAE080831GV
RMA History : 00
0x10: 42 48 30 80 00 00 00 00 02 02 C1 8B 4A 41 45 30
0x20: 38 30 38 33 31 47 56 03 00 81 00 00 00 00 04 00
SIMM slot 4: PVDM-12 SIMM present.
ebreniz
Level 6
Level 6
When the DSP farm is registered, the router shows the status as up. This is a normal operational behaviour
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a0080108fe6.shtml
