Aug 25th, 2007
Dear All,
I am getting the below message on FWSM console when try to create the vlan interface.Should i do anything on switch console
FWSM(config)# inter vlan 30
FWSM(config-if)# nameif outside
WARNING: VLAN *30* is not configured.
INFO: Security level for "outside" set to 0 by default.
JORGE RODRIGUEZ Sun, 08/26/2007 - 12:20
have you created vlan 30 in the switch engine and associated ports pertaining to that new vlan.. that warning message looks as it is leting you know that there is no vlan30 in switch to associate this interface with.
purohit_810 Mon, 08/27/2007 - 04:59
One thing possible ... you have already assigned Outside interface into that switch or VTP domain.
Dharmesh Purohit
RouterTech1 Fri, 12/07/2007 - 11:33
did you do anything to fix this? I am getting the same error message, even after making sure the vlan is up and designated in the fw group.
