these configuration right
Aug 26th, 2007
global (outside) 2 interface
nat (inside) 0 access-list exempt
nat (inside) 0 Xfuadc1 255.255.255.255
nat (inside) 0 Xfuadc2 255.255.255.255
nat (inside) 2 192.168.5.0 255.255.255.0
nat (inside) 2 X.X.X.0 255.255.255.0
nat (inside) 2 Subnet_172_17 255.255.0.0
nat (inside) 2 10.0.0.0 255.0.0.0
nat (dmz) 0 access-list nonat
nat (dmz) 2 Relay_DNS_1 255.255.255.255
make nat 0 for Dc ( domain Controller )
anandramapathy Mon, 08/27/2007 - 01:01
  • Bronze, 100 points or more
The config is ok, if this is just for Browsing.
If you have taken care of the NONAT for inside to DMZ & vice-versa then i think it should be fine.
HTH - pls rate if it helps
