08-26-2007 02:59 PM - edited 03-05-2019 06:06 PM
my reverse telnet shows open but I am not connected to the sw1
2511sw#telnet 192.168.10.10 2001
Trying 192.168.10.10, 2001 ... Open
when I do show line one .....I get this
2511sw#clear line 1
[confirm]
[OK]
2511sw#show line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns
* 0 CTY - - - - - 8 0 0/0
1 TTY 9600/9600 - - - - - 4 0 0/0
2 TTY 9600/9600 - - - - - 2 0 0/0
3 TTY 9600/9600 - - - - - 1 0 0/0
4 TTY 9600/9600 - - - - - 1 0 0/0
5 TTY 9600/9600 - - - - - 0 0 0/0
6 TTY 9600/9600 - - - - - 0 0 0/0
7 TTY 9600/9600 - - - - - 0 0 0/0
8 TTY 9600/9600 - - - - - 0 0 0/0
9 TTY 9600/9600 - - - - - 0 24 0/0
10 TTY 9600/9600 - - - - - 0 38 0/0
11 TTY 9600/9600 - - - - - 0 138 0/0
12 TTY 9600/9600 - - - - - 0 129 0/0
13 TTY 9600/9600 - - - - - 0 0 0/0
14 TTY 9600/9600 - - - - - 0 0 0/0
15 TTY 9600/9600 - - - - - 0 0 0/0
16 TTY 9600/9600 - - - - - 0 0 0/0
17 AUX 9600/9600 - - - - - 0 0 0/0
18 VTY - - - - - 0 0 0/0
19 VTY - - - - - 0 0 0/0
20 VTY - - - - - 0 0 0/0
21 VTY - - - - - 0 0 0/0
22 VTY - - - - - 0 0 0/0
08-26-2007 06:04 PM
karim
You are using the first TTY line for your reverse telnet. My first guess is some kind of connectivity problem. Can you confirm that you are connecting that first line to the device to which you want to console? Can you specify what kind of cable connection you are using? Can you confirm that the device to which you want to console will accept a direct connection on the console port?
Rick
08-27-2007 05:23 AM
thanks for the input, here is some more info that may help
I have a octal cable line 1 going to sw1 , 2 going to sw2. 3 going to R1 and 4 going to R2..on the server I did config a the loopback0 with 192.168.10.10....then I did configure the
# ip host sw1 192.168.10.10 2001
# ip host sw2 192.168.10.10 2002
# ip host r1 192.168.10.10 2003
# ip host sw2 192.168.10.10 2004
08-27-2007 10:55 AM
Did you used
#transport input all
Dhaval
08-27-2007 12:12 PM
I think I used
#transport input 1 6
08-27-2007 12:58 PM
Hi Karim,
Can you post the configuration of the termserver.
BR,
Mohammed Mahmoud.
08-28-2007 03:31 AM
Hi, ocporbust
There are two async ports on 2511 router.The lower port is labeled ASYNC 1-8, and the upper port is labeled ASYNC 9-16. Could it be that you are connecting to the upper port which is line 9-16?
SSLIN
08-28-2007 03:51 AM
A very good point SSLIN, and it can very very probably be the issue, Karim can you please confirm, and if still persist please post the configuration.
BR,
Mohammed Mahmoud.
08-28-2007 05:53 PM
good point will chk and get back to u .. Thanks
08-29-2007 07:01 AM
all the phisical setup is correcct ..I am connected to ASYNC 1-8.....
here is the config
2511sw#show config
Using 715 out of 32762 bytes
version 11.0
service udp-small-servers
service tcp-small-servers
hostname 2511sw
enable secret xxx
enable password xxx
no ip domain-lookup
interface Loopback0
ip address 192.168.10.10 255.255.255.0
interface Ethernet0
no ip address
interface Serial0
no ip address
shutdown
no fair-queue
interface Serial1
no ip address
shutdown
ip host sw1 2001 192.168.10.10
ip host sw2 2002 192.168.10.10
ip host r1 2003 192.168.10.10
ip host r2 2004 192.168.10.10
line con 0
password xxx
login
line 1 16
no exec
transport input telnet
stopbits 1
line aux 0
transport input all
line vty 0 3
login
line vty 4
password xxx
login
end
08-29-2007 08:28 AM
Hi Karim,
The configuration is fine, do you face problems when trying to connect to all the devices or just this switch.
BR,
Mohammed Mahmoud.
08-29-2007 09:37 AM
MO
I am not able to access all of them .. all I get is open message and its stays there.. I am going to see if I can connnect directly to each device
08-29-2007 09:48 AM
Karim,
If you can access them directly then it is most probably a cabling issue.
HTH,
Mohammed Mahmoud.
08-30-2007 07:08 AM
I am able to access all the devices but connecting directly to each one ..how it can be the octal ? I just useded last month .. may be it something else /..how I can find out ffor sure that its the cable ? .Thanks
08-30-2007 07:08 AM
I am able to access all the devices byconnecting directly to each one ..how it can be the octal ? I just useded last month .. may be it something else /..how I can find out ffor sure that its the cable ? .Thanks
