CSA 5.2 & rootkit detection
Answered Question
Aug 26th, 2007
Hello !
On two of our PCs there is special SW installed (Winternals and VMWare. During boot CSA detects this SW as rootkits and puts the systems in untrusted state. What is disturbing is that both machines are then begining to work in TESTMODE. After I reset system state of both agents systems continue to work normal, meaning that CSA is not in test mode anymore.
Any clue, how can I avoid putting in test mode when systems start ?
Correct Answer by tsteger1 about 9 years 9 months ago
Hello Marko, the Rootkit Lockdown Module is in testmode (by default) so anything triggered by the system state will also be in testmode.
I don't believe the systems are in testmode, just the alerts from this rule.
Tom
Overall Rating: 4.5 (2 ratings)
Correct Answer
tsteger1 Mon, 08/27/2007 - 22:24
  • Red, 2250 points or more
Tom
m.vuckovic Tue, 08/28/2007 - 05:20
Tom,
thank you very much. You're absolutely right. I trust those applications, so I will make an exclusion for them.
Best regards, Marko
