08-27-2007 12:13 AM - edited 03-03-2019 06:28 PM
How can I get the ipv6 address from the ipV4 address ??
Regards...
08-27-2007 01:13 AM
The only case that has got a relation between IPv4 and IPv6 is when using IPv4-Compatible-IPv6 unicast. An IPv4-compatible IPv6 address is an IPv6 unicast address that has zeros in the high-order 96 bits of the address and an IPv4 address in the low-order 32 bits of the address.
The format of an IPv4-compatible IPv6 address is 0:0:0:0:0:0:A.B.C.D or ::A.B.C.D.
The entire 128-bit IPv4-compatible IPv6 address is used as the IPv6 address of a node and the IPv4 address embedded in the low-order 32 bits is used as the IPv4 address of the node.
IPv4-compatible IPv6 addresses are assigned to nodes that support both the IPv4 and IPv6 protocol stacks and are used in automatic tunnels.
HTH,
Mohammed Mahmoud.
08-27-2007 01:24 AM
try this link - IPConvert will take a standard IPv4 IP address, in the standard dot notation format, and display it as an IPv6 IP address
