STP & portfast
cvf-reg2cis
I have a question about STP.
STP (rstp) is enabled on several switchs for a vlan which doesn't need it (there are no loops possible). On this vlan there are edge ports which doesn't have the portfast option activated.
Each time I plug or unplug a port in this vlan, I have a quite (30 sec) long outage due to the recomputation of the STP protocol.
My question : I would like to solve this problem, either by disabling STP for this vlan, either by setting the portfast option on the edge ports.
What is the best way to solve the problem, without generating a new outage ?
In other words, can I desactivate the STP (one switch after the other) without generating an outage. And can I set the portfast option on a port without generating an outage.
Thanks a lot
Guillaume
3 Accepted Solutions
rajatsetia
You can configure edge "access" ports for portfast option without any outage.
use this command "spanning-tree portfast" under interface config.
along with that I will recommend to use
"spanning-tree portfast bpduguard default" in global config.
So that BPDU-guard is enabled on the portfast enabled interfaces, in case another switch is connected to any of the portfast interface by mistake , the concerned interface will be disabled.
rgds
kerek
Level 4
Level 4
1. I think it is better to use portfast (with bpdu guard)instead of turning off the stp in that particular vlan. In that case portfast will not cause any outage as it puts the port into forwarding state as connected but still prevent from bridging loop to occur if inadvertently connect a switch as stp takes care of that.
2. In order to disable stp per vlan and let run in others obviously needs pvstp (per vlan stp) and will not cause outage if disabled per vlan.
Krisztian
Guillaume:
It is a BAD practice to disable STP. STP has very little bandwidth overhead and can save you from a disaster. I would not disable it.
Simply add portfast to the access ports, as the gentlemen have described, and then enable bpduguard.
13 Replies 13
rajatsetia
rgds
kerek
Level 4
Level 4
Krisztian
Guillaume:
jorgenolla
If there are no loops on your topology, you should have no instances of STP (RSTP) running.
#show spanning-tree
Should show that there are no instances of STP running. To remove the forward delay time on the interfaces, you need to use portfast on the edge ports.
Jorgenolla:
I had to sound brash, but you are wrong, my friend. it is a Cisco "best practice" to always enable STP becuase you dont know how th etoplogy might change in the future and it prevents accidents, like someone plugging a switch into what is supposed to be an access port.
Of course, in the end, it is up to the net admin to decide what he/she wants to do, but disabling SZTP buys you almost zero and can leave you vulnerable.
oops, I meant to say that I "hate" to sound brash..
To: lamav
Thanks my friend, but I think you re missing the point.
You are very correct in your statement: "best practice" to always enable STP".
STP is enabled by default; and I did not say to disable STP!
But when there are no present loops in the Topology, there will be no instances of STP running!!!!!!!!!!!!!!!!!
If a loop is formed at some point, then STP will have an instance for each VLAN in the network.
Best Regards
"But when there are no present loops in the Topology, there will be no instances of STP running!!!!!!!!!!!!!!!!!"
That is an incorrect statement, Jorge. Please see my post to you on the other thread you commented on this morning.
And by the way, 1 exclamation point would have been enough!...!!!!!!! (smile).
Just replied to you on the other post lamav.
Once again I think you've misunderstood. I said "Instance of STP", which is different than "STP".
Best regards
Hi Jorge
I'm not sure i understand your point. You seem to be suggesting that if you have no loops in your network then you will have no instances of STP and to prove the point you say that the output of a "sh spanning-tree" will not show any instances.
This is the output of a "sh spanning-tree" on a 3560 which is connected via a trunk link to a 3550 ie. only one link no loops.
lab_sw1#sh spanning-tree
VLAN0001
Spanning tree enabled protocol ieee
Root ID Priority 32769
Address 000a.b8b3.a980
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32769 (priority 32768 sys-id-ext 1)
Aging Time 300
Interface Role Sts Cost Prio.Nbr Type
Fa0/48 Desg FWD 19 128.52 P2p
VLAN0010
Root ID Priority 32778
Bridge ID Priority 32778 (priority 32768 sys-id-ext 10)
Aging Time 300
Fa0/21 Desg FWD 19 128.23 Edge P2p
VLAN0011
Root ID Priority 32779
Bridge ID Priority 32779 (priority 32768 sys-id-ext 11)
Aging Time 300
Could you clarify what you mean by "no instances" ?
Jon
Jon & and Lamav:
I don't know what was I thinking! I was incorrect, and thanks for clarifying that Jon.
I was thinking about MST and the command
spanning-tree mst configuration
Best Regards
cvf-reg2cis
Thanks all for your helpful answers !
kesva.naidoo
The Cisco implementation maintains that the Portfast keyword be used for edge port configuration.
http://www.cisco.com/en/US/partner/tech/tk389/tk621/technologies_white_paper09186a0080094cfa.shtml#converge2
See page 8.
