DL320-G2 Communications Manager 6.0
Aug 27th, 2007
I just got the CUCM 6.0 Disc set and I like to setup a new Communications server. The media check works fine, but then it shows me, that the server is incombatible altough the server is listed in the compability matrix! ( http://www.cisco.com/en/US/products/hw/voiceapp/ps378/prod_brochure0900aecd8062a4f9.html ) I'm using a DL320-G2 with a Intel 3.06Ghz and 1GB DRAM. So what is wrong?
Has somone made the same experience?
Peter
pwenger Tue, 08/28/2007 - 00:40
Your right, I found it in the release notes before I got your answer.
Anyway, thanks a lot.
Peter
