Access-list Switch 3750
Aug 27th, 2007
I request your assistance to set up access-list in order to prohibit the dialogue between VLANs. In my config I have 10 VLANs and I would not like that they discuss between them, but except my VLAN 4 (Administration) I have my dhcp configured above.
In short: 10 VLANs and allow just the dialogue with the VLAN 4 and to prohibit all.
Herewith my config current of the switch:
Thank you
Jon Marshall Mon, 08/27/2007 - 01:59
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
access-list 101 permit ip any 192.168.0.0 0.0.0.255
access-list 101 permit deny ip any any
interface vlan2
ip access-group 101 in
interface vlan3
Couple of things to note
1) This will only allow vlan 2 / 3 etc. to talk to vlan 4. They will not be allowed to talk to any other destination IP addresses.
2) You don't have to use the same access-list number (101) for every vlan interface if you don't want.
3) If you want to allow your vlans to talk to external IP addresses other than those on the switch your access-list would look
for vlan 2
access-list 101 deny ip any 192.168.3.0 0.0.0.255
access-list 101 deny ip any 192.168.6.0 0.0.0.255
etc... for each of your vlans
access-list 101 permit ip any any
Jon
amirovic13 Mon, 08/27/2007 - 03:29
Thank you very much for your assistance. I will test and I will keep you informed
amirovic13 Mon, 08/27/2007 - 03:34
What is the difference if I change the access-list number for every VLANs ??
Jon Marshall Mon, 08/27/2007 - 06:58
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
If you wanted to see how many hits per vlan you are getting then use separate access-lists or if you need to be more granular and the rules are not exactly the same per vlan.
Jon
