packet-buffer err-disable .. i don't understand.
Aug 27th, 2007
Error for WS-X6516-GE-TX
03:23: %PM_SCP-SP-2-LCP_FW_ERR_INFORM: Module 6 is experiencing the following error: Transient port ASIC (PINNACLE) packet buffer parity error detected on ports 1, 2, 3, 4,
00:03:23: %PM-SP-4-ERR_DISABLE: packet-buffer error detected on Gi6/1, putting Gi6/1 in err-disable state
00:03:23: %PM-SP-4-ERR_DISABLE: packet-buffer error detected on Gi6/2, putting Gi6/2 in err-disable state
00:03:23: %PM-SP-4-ERR_DISABLE: packet-buffer error detected on Gi6/3, putting Gi6/3 in err-disable state
00:03:23: %PM-SP-4-ERR_DISABLE: packet-buffer error detected on Gi6/4, putting Gi6/4 in err-disable state
thanks for you. it's help to me.
purohit_810 Tue, 08/28/2007 - 10:01
It could be cause of following:
A cable that is out of specification (either too long, the wrong type, or defective)
A bad network interface card (NIC) card (with physical problems or driver problems)
A port duplex misconfiguration
To eliminate the problem.. follow below document check one by one.
http://www.cisco.com/en/US/tech/tk389/tk621/technologies_tech_note09186a00806cd87b.shtml
Dharmesh Purohit
