New Cert Tracking misses passed Tests?
Aug 27th, 2007
I'm about to take the final test (MPLS) I need to fullfill the CCIP requirements. Yesterday I did a quick check of the Certification Tracking System to see if everything up to date. And what did I see? The Tracking system is a new system since 1st August (at least it tells this in the FAQ).
Everything is listed in it (History show passed tests as the should ) and progress shows the certifications I hold, but under CCIP it says 'not started' and the BSCI (already done that for CCNP, show up there), QOS and BGP tests I already passed are not listed.
Does anybody know is this a normal effect of the transition and if this turns out normal after I passed the final MPLS test?
