SPAN - ASA inside port on a 3750 switch - Time-outs
Aug 27th, 2007
  • Bronze, 100 points or more
I have 2 ASAs 5520 AIP-SSM in Active/Failover mode connected to 2 3750 Switches.
The 2 3750 switches are trunked with each other & are the LAN Gateway running HSRP for the LAN. They also have a couple of VLANs & are running EIGRP ( connected to the Core switces via Gigabit Uplink )
I am spanning the Inside interface connected to the 3750 switch onto a Surfcontrol Server for url Filtering.
The moment i span the port, i start getting occasional timeouts when i ping the internal interface of the ASA 5520.
There are no errors / CRC on either the Switch / the ASA.
THe inside Interfaces are 1000 MB / Full Duplex
Can someone help me troubleshoot.
jbayuka Fri, 08/31/2007 - 10:34
I think you would need to add to disable the IDLE-TIMEOUT for the ezvpn tunnel;-
group-policy ashford-ezvpn attributes vpn-idle-timeout 0
If it does fail again, we would need a capture of the tunnel going down with the vpn debugs currently running on ASA and router.
