ACE Port console
Aug 27th, 2007
i cannot have access on ACE console port
using 'session slot 4 processor 0', i can see that no special cfg for line console is done
i used another ACE module with same terminal (secureCRT 5.0.5) and now i can see script when ACE reload but i can't type anything
any idea?
bwilmoth Fri, 08/31/2007 - 10:35
  • Silver, 250 points or more
You will need to add another interface to the ACE to were the servers are connected and set source NAT on the ACE so that connections from the server will hit the ACE and not go directly to the clients
lacirasella Sun, 09/02/2007 - 23:00
sorry but that was not my question. On the physical module ACE, there is a console port (9600,8,n,1) and a cannot have access to this serial console port. It is not a question of telnet or anything else.
