Required components of CiscoWorks for inventory
Aug 27th, 2007
Hello! What components of CW should I use for config and software management and for inventory? For example can I use CW without DFM and Campus manager for this purposes? Should it be cheaper, then whole CW?
Joe Clarke Mon, 08/27/2007 - 08:21
The Resource Manager Essentials application does both config and software management. You cannot purchase individual LMS components. You must buy the whole bundle.
Joe Clarke Tue, 08/28/2007 - 09:01
No. When you purchase CiscoWorks LAN Management Solution, you have to purchase a support contract on the entire bundle (or no contract at all).
