Step 1 Start BAT.
Step 2 Click Configure > insert Phone ---> Step 1: Add, view, or modify phone templates
Step 3 From the list of templates, choose the template for which you want to add speed dial(s).
Step 4 Click Update Speed Dial Buttons in the upper, right corner of the window.
A pop-up window displays. In this window, you can designate speed dial buttons for base Cisco IP Phones and "AbbrDial". The number of speed dial buttons available for this template depends on the Phone Button Template in use for this BAT template.
Step 5 In the Speed Dial Settings for Base Phone area, enter the number in the Speed Dial Number fields, including any access or long distance codes.
Step 6 In the Speed Dial Label fields, enter a corresponding label for each speed dial number you entered.
Step 7 Repeat Steps 5 and 6 to set speed dials for another range of numbers
Step 8 Click Update and Close.
