Report generator -> bug toolkit
Answered Question
Aug 27th, 2007
Hello
We have about 300 cisco devices. I launched bug toolkit (RME->Reports->Report Generator->Bug toolkit)against all switches (150 devices), and i was very surprised to notice that there was no single bug !
Is it possible ? Or i haven't downloaded "bugs database" to cisco works ?
Thanx
Correct Answer by Joe Clarke about 9 years 10 months ago
You can't. This was documented in a bug, CSCse38322, and the "fix" was to add the Cisco.com link.
Overall Rating: 5 (1 ratings)
Joe Clarke Mon, 08/27/2007 - 08:20
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
There have been numerous version/platform matching issues with this tool. This is especially true with XL switches. The workaround is to go straight to Cisco.com to do your bug reporting. If you have RME 4.0.5 or later, you should see a link in the GUI to do this. If not, the link is http://www.cisco.com/cgi-bin/Support/Bugtool/selection.pl?mdf_label=Cisco+IOS+Releases&Submit3=Next&cco_product=IOS .
mlopacinski Mon, 08/27/2007 - 22:28
Yes - and my devices are vulnerable. So why bug report do not find any bugs ?
Joe Clarke Mon, 08/27/2007 - 22:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Most likely because the database that the Bug toolkit uses does not contain your product and versions. That's why RME 4.0.5 added the Cisco.com link so the official Bug Toolkit can be used to ensure you have the most accurate information.
mlopacinski Mon, 08/27/2007 - 22:45
ok, but this link to cisco.com bug toolkit force me to do it manually - to type each device model/version and check if it's vulnerable. I wanted to use RME Report Generator (Bug Toolkit) to automate this process - to see which of my 350 devices is vulnerable, and to focus only on vulnerable devices (without need to analyze manually all devices). I have RME 4.0.5. Can i do it ? How can i fix report generator bug toolkit in RME ?
Correct Answer
Joe Clarke Tue, 08/28/2007 - 09:00
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
mlopacinski Mon, 08/27/2007 - 22:29
