Update Directory Number with BAT or AXL ?!
Aug 27th, 2007
Hi !
We have a cluster of 5 CCM 4.2(3)sr1 with 1700 phones.
W have to change All DN because we change the dial plan : from 4 digits to 6 digits.
That means we have to update all DN, Forward on busy internal & external, Forward on no answer internet & external...
I checked if it's possible with BAT to update the lines with a csv file but it isn't.
The only way I found is :
To export all phones
Create a new BAT File
delete all phones
insert the new BAT File.
But it's really not convenient : the export gave too much infos and I am afraid to loose something like the speeddials, configured services ...
So the best ideal is only to upgade the DN. I read somes documentations this morning about AXL.
Do you think it can be done with AXL ? to only update the DN and forward ?
Thanks you a lot for your help !!!
What do you think ?
Thanks you a lot !
PS We are using CCM 4.2(3)sr1
