Command help.
Aug 27th, 2007
Is there a command to put all ports in the isolated vsan?
I am setting up 2 new 9509's
The thought is to initially put all ports in vsan 4094. Then as my Prod, Backup and SRDF vsans are created ports will be allocated to their assigned vsan
The customer has a lot of unused ports at this time so the unused ports would be left in vsan 4094
Is this common practice? Thoughts?
Overall Rating: 5 (1 ratings)
colin.mcnamara Mon, 08/27/2007 - 07:53
Sleep well, you are following the best practice.
Colin McNamara
CCIE #18233 - Storage Networking
inch Tue, 08/28/2007 - 04:07
I usually make vsan 1 my isolated vsan as when someone adds a new line card all ports automatically get put into vsan 1 :)
nitro_rs4 Tue, 08/28/2007 - 09:10
Be real careful with this command. You enter something wrong and bang you take down your systmes.
Config -t
vsan database
vsan 4094 interface fc 1/1-48
copy run start
Of course, you have to enter the module and port numbers that match your setup.
spwvol1978 Tue, 08/28/2007 - 09:12
Thanks nitro.
This will be done on the initial setup of the switch b4 anything is plugged in.
Trending Topics: Storage Networking
