POE cable for 1310
Answered Question
I need a POE cable of 40 meters between the 1310 bridge and the power injector.I found this reference: AIR-CAB100DRG6-F.
It's OK for a 1310?
Correct Answer by rob.huffman about 9 years 2 months ago
Hi Herve,
I think you are better off ordering up a custom length cable (RG6 Coax with F-Type connectors). Here is an example of someone who makes up custom cables;
Hope this helps!
Overall Rating: 5 (1 ratings)
rob.huffman Mon, 08/27/2007 - 08:16
Hi Herve,
Yes, that Dual-Coax cable assembly will be perfect for your needs. This cable is referred to as a side note in some of the 1310 docs so you should be good to go :)
Hope this helps!
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
