BAT with IP Address Autodetection URL field
Aug 27th, 2007
I need to update several hundred IP Communicators with a new address in the field "IP Address Autodetection URL". I am using Call Manager 4.13 with BAT 5.14c.
BAT doesn't allow you to change the "IP Address Autodetection URL"
How can I update all of these IP Communicators in bulk? Query in SQL??
dsweeny Fri, 08/31/2007 - 10:58
Use CCMAdmin to update Cisco IP Communicator fields such as:
LDAP Server Information File
RTP Port Range Start
RTP Port Range End
Verify Software Versions
Sascha Monteiro Mon, 10/08/2007 - 00:37
  • Silver, 250 points or more
you might be able to do with with AXL, with the vendorConfig elements in updatePhone
if so, I know where you can buy a tool to bulk update settings via AXL
