Global Objects in PIX 7.2
Aug 27th, 2007
Hello All,
I am seeing a unique problem whenever I create Network Object group in PIX firewall an other Network Object group with same name_ref is also created on the firewall.
For example, I created a group called webserver group an new group called wbserver_ref_1 was also created
I narrowed down the issue. It happens only for groups which have NATted hosts.
The webserver group contains hosts with private IP addresses and webserver_ref_1 group contains the same hosts with their public addresses as members.
How do I overcome this issue. Should I create only the Public IP addresses in the network group or should I rename the internal hosts to different group id.
Please help
