Unity 5.X
Answered Question
Aug 27th, 2007
Does Unity 5.X supports unified messaging and voicemail on the same box ? it it does could you provide documentation about it and maybe config guides
thant you
Correct Answer by Christopher McAlpin about 9 years 9 months ago
Correct the minimum of 1500 users requirement has been lifted and no longer applies.
Overall Rating: 5 (2 ratings)
Christopher McAlpin Mon, 08/27/2007 - 10:37
  • Cisco Employee,
This is supported...
Licensing for Mixed Voice Messaging/Unified Messaging (for Cisco Unity Version 4.2 with Microsoft Exchange)
http://www.cisco.com/en/US/products/sw/voicesw/ps2237/products_white_paper09186a0080623fa8.shtml.
Note the document makes refrence to the following stipulation which I believe has sence been lifted:
Note Mixed licensing is supported only for deployments of Cisco Unity 4.2 with more than 1500 users, as of March 2006.
cris_jimenez Mon, 08/27/2007 - 10:47
thank you for your reply
we want to deploy unity 5 actually, the same rule applies for mixed licensing in unity 5?
Do we need to have more thatn 1500 users deployed in Unity 5 to be able to mix licenses and have the server supported by TAC?
Correct Answer
Christopher McAlpin Mon, 08/27/2007 - 11:29
  • Cisco Employee,
cris_jimenez Mon, 08/27/2007 - 13:32
Is there a way to configure failover in this hybrid environment?
The Cisco documentation that I've found so far explains it but its either UM or VM not both
thank you
Cris
