Retake CCNA; will it be the same test?
Aug 27th, 2007
If I retake the CCNA exam (640-801), will it be the same Exam/Questions?
I just failed the CCNA (got a 770). I can retest next week. I got hung-up on a Switch-Sim that ate up 15min and was pressed for time after that.
Pari Thiagasundaram Mon, 08/27/2007 - 11:14
To my knowledge, there is no reason that you would get the same questions.
From my personal experience, i did not get the same questions.
Good luck for your certifications.
nyamuthullas Tue, 08/28/2007 - 05:52
If you write with in a wee then you will get the same questions and you can go ahead with tht.
Good luck
