ospf route missing
Answered Question
Aug 27th, 2007
router B sits between Routers A and C and is connected to both via international serial links. As a backup there is a GRE tunnel across the internet between routers A and C. Router A has a private LAN on Area 0 but everything else mentioned here is in Area 3.
Router A's private LAN is visible by all routers however Router C's private LAN is neither visible by routers A nor B.
WHY?
Correct Answer by sundar.palaniappan about 9 years 7 months ago
Configuration looks OK. Do you have a static route to 10.5.4.0/24 on Router B? If you do then can you remove the static route and the OSPF route would be installed in the routing table.
If you aren't using static routes can you post the output of 'show ip ospf database router 10.5.4.1' from Router B.
Sundar
Overall Rating: 5 (1 ratings)
Pari Thiagasundaram Mon, 08/27/2007 - 11:24
  • Silver, 250 points or more
Too few informations.
Let me ask you the following questions.
1) Your heading says "ospf route missing". Is ospf running on all 3 routers?
2) Are the private LANs addresses advertised on router C ?
3) What does your config look like (sh run and sh ip route ) on all 3 routers
ldmccalla Mon, 08/27/2007 - 13:22
other than the static routes i have in place to force all traffic via router B, everything else is attached.
Correct Answer
sundar.palaniappan Mon, 08/27/2007 - 13:37
  • Green, 3000 points or more
Sundar
Pari Thiagasundaram Mon, 08/27/2007 - 11:28
lamav Mon, 08/27/2007 - 11:54
  • Blue, 1500 points or more
I think its impossible to really answer this question until you post the configs of all routers involved.
