Dual Supervisor Engine on 4507 Switch
Answered Question
Aug 27th, 2007
I have a Catalyst 4507 Switch with dual supervisor engine module. In my configuration, i have the commands below:
redundancy
mode sso
However, when a enter the command show slavebootflash:, i got this error message
%Error show slavebootflash: (Error Sending Request)
What's wrong?
Thank you.
Correct Answer by ankbhasi about 9 years 9 months ago
Hi Ricky,
You call is slave when you are on active sup but when you are local to that sup you call it bootflash. So as you confirm your standby sup is in rommon , please console into the standby sup and issue a command "dir bootflash:"?
Ankur
Overall Rating: 5 (1 ratings)
Edison Ortiz Tue, 08/28/2007 - 05:11
  • Hall of Fame,
    Founding Member
Can you post the output from typing
'dir /all' and 'show redundancy'
rickyhadlocon Tue, 08/28/2007 - 07:08
Hello Edison,
Below is the result of show redundancy:
Redundant System Information :
Available system uptime = 20 hours, 3 minutes
Switchovers system experienced = 0
Standby failures = 0
Last switchover reason = none
Hardware Mode = Duplex
Configured Redundancy Mode = Stateful Switchover
Operating Redundancy Mode = Non Redundant
Maintenance Mode = Disabled
Communications = Down Reason: Simplex mode
Current Processor Information :
Active Location = slot 1
Current Software state = ACTIVE
Uptime in current state = 20 hours, 2 minutes
Image Version = Cisco Internetwork Operating System Software
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9K91S-M), Version 12.2(20)EWA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 08-Sep-04 18:33 by kellythw
Configuration register = 0x2102
Peer (slot: 2) information is not available because it is in 'DISABLED' state
Thank you.
ankbhasi Tue, 08/28/2007 - 07:18
  • Cisco Employee,
Hi Ricky,
I believe your tandby sup is on rommon mode. Can you console into your second sup and check the status if you get anything on console? If it is in rommom then you can probably boot it manually from the image it must be having in slave bootflash and once it boots up we can copy the image which you have on active sup to standby sup.
Ankur
rickyhadlocon Tue, 08/28/2007 - 07:54
Hello Ankur,
You are correct, the standby sup in on rommon mode. Will i proceed with the command copy bootflash: slavebootflash: ?
Thank you.
ankbhasi Tue, 08/28/2007 - 08:00
  • Cisco Employee,
Hi Ricky,
Nops if it is in rommon this command wont work on active sup. So you have to manually boot your standby sup which is in rommon mode first.
Can you issue a command "dir flash" from rommon mode and confirm if you have any image available on your bootflash?
Ankur
rickyhadlocon Tue, 08/28/2007 - 08:04
This switch is up and running. There's an IOS image under bootflash:
ankbhasi Tue, 08/28/2007 - 08:06
  • Cisco Employee,
Hi Ricky,
So you do see some image in your sup bootflash which is in rommon correct? Can you confirm the exact image name? Also if this switch in production?
Ankur
rickyhadlocon Tue, 08/28/2007 - 08:17
Actually, sup slavebootflash is the one in rommon not bootflash. The image name is "bootflash:cat4000-i9k91s-mz.122-20.EWA.bin"
Correct Answer
ankbhasi Tue, 08/28/2007 - 08:24
  • Cisco Employee,
Hi Ricky,
Ankur
rickyhadlocon Tue, 08/28/2007 - 08:29
Thanks for clarifying that. There are no image listed when i do "dir bootflash:"
Thanks.
rickyhadlocon Tue, 08/28/2007 - 09:36
Below is the result for dir all-filsystems command:
Directory of bootflash:/
1 -rwx 12861032 Oct 19 2004 17:45:36 -04:00 cat4000-i9k91s-mz.122-20.EWA.bin
27262976 bytes total (14401816 bytes free)
Directory of slot0:/
No files in directory
63897600 bytes total (63897600 bytes free)
Directory of system:/
2 dr-x 0 memory
1 -rw- 30607 running-config
9 dr-x 0 vfiles
No space information available
Directory of crashinfo:/
1 -r-- 9036 data
2 -r-- 28488 data.bin
Directory of cat4000_flash:/
1 -rw- 796 vlan.dat
524280 bytes total (523484 bytes free)
Directory of nvram:/
504 -rw- 6500 startup-config
505 ---- 27 private-config
1 ---- 4 rf_cold_starts
524280 bytes total (516677 bytes free)
Directory of profiler:/
1 -r-- 0 data
Thank you.
Edison Ortiz Tue, 08/28/2007 - 08:00
  • Hall of Fame,
    Founding Member
You have your answer on the output. Slot2 is down. You may have a hardware problem or the Supervisor in Slot2 is in rommon mode as stated by Ankur.
Follow his suggestions on how to approach this problem but also be sure to read this document:
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/12_2_37s/config/rpr.htm
