1811 8-port switch
slayerhawk
Hey all. I usually use 1750 routers and connect E0 to the WAN link and FA0 to the LAN ip.
Now, I have an 181 with 2 FA ports and an 8 port built in switch. How can I put all 8 ports into a vlan sharing the same ip range so that I don't have to use an external switch directly plugged into fa1?
Assume that fa1 is ip 192.168.1.2/24.
Jon Marshall
router(config)# vlan database
router(vlan)# vlan 10 media ethernet name vlan10
router(vlan)# exit
This will create your vlan.
Create your layer 3 interface for vlan 10
int vlan 10
ip address 192.168.1.2 255.255.255.0
no shut
to add ports to that vlan
int fa2
switchport mode access
switchport access vlan 10
spanning-tree portfast
Jon
All the switch ports are in VLAN1 by default, but this is a more secure method.
And FYI, in global config mode, you can do "int range fa2 - 9" and edit all 8 switch ports at once.
Saves a little time. And only use the portfast command if you're sure no one will be plugging in any switches downstream.
