CHUNKMALLOCFAIL error on 12.4T on 7206-NPE-G2
Answered Question
Aug 27th, 2007
Newly upgraded firmware on a G2:
12.4(15)T1
Aug 26 12:50:53.611: %SYS-4-CHUNKMALLOCFAIL: Could not allocate chunks for CEF:
arp throt
Total free: 0, Total inuse: 500, Cause : Not a dynamic chunk
Followed by a traceback.
The router does not crash, so seems this is not fatal, but I don't like it.
Any ideas on a cause or a solution?
Roger
Correct Answer by Robert Taylor about 9 years 5 months ago
This is a known resolved bug. Typically seen when you are overloading your router with lots of packets >512bytes.
BugID is CSCsj25679 and should be fixed after 12.4(16)T although I dont think its released yet.
Open a TAC case if you need a special image released, or wait until the next version of 12.4T is released.
Overall Rating: 5 (1 ratings)
Correct Answer
Robert Taylor Tue, 08/28/2007 - 08:35
adavenport Tue, 08/28/2007 - 10:42
Thanks very much. I feel better that its not impacting traffic. This bug did not appear in XD train for this platform, even though bugtrak says it existed there.
Roger
