How NAT works in this design?
Aug 27th, 2007
Hi forum,
we were given this network design in order to integrate with another company's network. Network A is our network running EIGRP, Network B is our partner's network running EIGRP as well.
R1(router) will policy route traffic that has been changed to to R2, and will policy route those conflicting IP address to R3 before going to R2.
How should I configure my DNS in this case? How NAT actually works in this case?
Thanks much,
Overall Rating: 5 (1 ratings)
Pavel Bykov Tue, 08/28/2007 - 00:59
DNS in your network should point to translated addresses of the other network.
NAT works both ways in this example, so devices in one network communicate to OUTSIDE LOCAL address, which is translated afterwards to the OUTSIDE GLOBAL.
In your example:
Perspective 1:
NET1 = inside local
NET1 = outside local
NET2 = outside global
NET2 = inside global
Perspective 2 is reversed.
These two documents will help you understand the concept better:
Hope this helps.
Plese rate all helpful posts.
