CISCOWORKS SNMS support for Catalyst Express 500 24TT
Aug 27th, 2007
Hi, we?d CW SNMS installed, and we also applied the nmidb.10.088 update, but What`s UP does not seem to support the Catalyst Express 500 switches. ?What another update is neccesary to support them?
Joe Clarke Mon, 08/27/2007 - 19:06
The CE500 switches should be managed by Cisco Network Assistant which is freely downloadable from Cisco.com from the same location you download CE500 software.
juliocarossella Tue, 08/28/2007 - 07:49
Ok, thank you
...but it is supposed that both (CE 500 switch and CW SNMS) are aimed to small/medium networks. Don?t you look for a comprenhensive and integral management application?
How could I imagine a network running different managers for each device type?
Joe Clarke Tue, 08/28/2007 - 09:19
I am not the one to answer that question. The decision to have CNA support the Catalyst Express came from the product manager for the CE.
