how to use static and dynamic nat simultaneously?
Aug 27th, 2007
hi,
I need to config static and dynamic nat simultaneously on router.But the static nat IP ranged are included dynamic nat IP leg.How do I implement it,thanks a lot.
I did it like this,but it functioned unsuccessfully.why?
ip nat pool nat 10.167.4.209 10.167.4.209 netmask 255.255.255.240
ip nat source list 1 pool nat overload
ip nat inside source static 192.168.3.13 10.167.4.211
ip nat inside source static 192.168.3.14 10.167.4.212
ip nat inside source static 192.168.3.15 10.167.4.213
ip nat inside source static 192.168.3.16 10.167.4.214
ip nat inside source static 192.168.3.26 10.167.4.220
ip nat inside source static 192.168.3.27 10.167.4.221
ip nat inside source static 192.168.3.32 10.167.4.222
logging 10.167.8.67
access-list 1 permit 192.168.3.0 0.0.0.255
Respects,
Minquan
Jon Marshall Mon, 08/27/2007 - 19:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Minquan
Try this config.
router(config)# ip nat pool nat prefix-length 28
router(config-ipnat-pool)# address 10.167.4.209 10.167.4.210
router(config-ipnat-pool)# address 10.167.4.215 10.167.4.219
router(config-ipnat-pool)# address 10.167.4.223 10.167.4.223
Leave your static translations as is.
Jon
