CRA Script string operation
Aug 27th, 2007
Can,t concatenate strings together, have three string entered by caller(GetDigitString) and do set
variable = digits1.concat(digits2).concat(digits3)
validate succesfull
nothing happens
debug said java extensions are not licensed to support method invocations
what can i do to concat strings in my scripts ?
Overall Rating: 3 (2 ratings)
sferland Tue, 08/28/2007 - 04:20
  • Bronze, 100 points or more
You can use the + operator for the concatenation.
variable = digits1 + digits2 + digits3
Hope that help !
daemon_sid Mon, 09/03/2007 - 04:42
Hi, thanks for answer.
I try + operator first, then try concate form expression variable in ScriptEditor and nothing works, may be problem is in license ? We have IPCC Express, may be need IPCC Enterprise?
david.macias Mon, 09/03/2007 - 12:49
  • Blue, 1500 points or more
Try to concatenate two simple numbers and see what happens, I don't think you need express premium to accomplish this.
david
daemon_sid Tue, 09/04/2007 - 21:15
Hi, i found problem it was not in concate but in
GetDigit. Thanks for answers.
