XENPAC-10GB- LR Maximum Power Receive
Aug 27th, 2007
Hi is there a maximum power receive for a
XENPAC-10GB- LR ? In the Cisco specification is only the minimum power receive of -8.2dbm
thanks for replay
markus
andrew.burns Tue, 08/28/2007 - 00:47
  • Gold, 750 points or more
The datasheet gives the following values:
Max Transmit Power 0.5dBm
Min Transmit Power -8.2dBm
Max Receive Power 0.5dBm
Min Receive Power -14.4dBm
Link here:
http://www.cisco.com/application/pdf/en/us/guest/products/ps6574/c1650/ccmigration_09186a008007cd00.pdf
The confusion arises because the html table is corrupted - use the above pdf link as the correct reference.
Andrew.
