two E1 interfaces
Aug 28th, 2007
On a router 2801 I have one E1 interfaces to PBX and other to PSTN configured as PRI ISDN. Also I have Frame-Relay link to remote location where is CCME. How do I have to configure router with dial-peers that users from PBX can dial outside as they usually do with PBX (they dial 0 to access outside)?
smalkeric Mon, 09/03/2007 - 08:43
  • Silver, 250 points or more
In order to match outbound dial peers, the router or gateway uses the destination-pattern dial peer command.
On Plain Old Telephone Service (POTS) dial peers, the port command is then issued to forward the call.
On Voice-Network dial peers, the session target command is then issued to forward the call.
When outbound peers are matched, the user must consider Direct Inward Dial (DID) cases as well as non-DID.
