CUE in India
Aug 28th, 2007
Trying to implement a CUE system in India. As it's India we have seperate the PSTN and VoIP lines on the phones using PT and CSS. Thats fine. Does anyone have any good idea's how to configure Unity express voicemail so it's accessible from either line given that there completely seperate?
Cheers
Markus Schneider Tue, 08/28/2007 - 06:23
CUE does support a phonenumber and phonenumber164. Those can be completely separate. For example (in the CLI):
username jdoe phonenumber 1234
username jdoe phonenumber164 84844
The only issue is that for transfers (e.g. when transferring the user's extension from the CUE auto attendant) it'll transfer to the number that's the primary extension. Also, MWI will be sent to the primary extension.
