L2TP traffic
Aug 28th, 2007
I have configure a L2TP VPN with dynamic map. My users connect perfect, but I would like to tunneled only traffic to my network, and let web and mail traffic use their internet connection. I did use "split-tunnel-network-list" but it did not work. Meanwhile, using this with VPN IPsec with Cisco client, works perfect. Any ideas? Thanks.
bwalchez Mon, 09/03/2007 - 08:45
The reason I think your split tunnel is not working is because you have not configured the access list used for split tunnel properly. Also make sure you have configured split tunneling with command "vpngroup group_name split-tunnel access_list".
