Active Standby OSPF
Answered Question
Aug 28th, 2007
Hi.
I have a pair of 5520 configured for active/standby failover.
They are also running OSPF and encrypting WAN links.
From another site I can Ping/SSH to the active unit but not the standby.
I logged onto the standby via con port and found it had no routes. If I add a static route to the config both units are accesible.
Is there a way to get the OSPF routing table to update on the active and standby at the sametime?
John
Correct Answer by srue about 9 years 8 months ago
unfortunately dynamic routes are not replicated in failover.
Overall Rating: 5 (1 ratings)
Correct Answer
srue Tue, 08/21/2007 - 15:35
  • Blue, 1500 points or more
