Upgrade PIX 535, licensing question.
Answered Question
Aug 28th, 2007
I recently purchased a PIX 535, it came with 6.3(5). My question is, can I upgrade to the 7.x/8.x software directly or do I need to purchase a license for the new software?
Correct Answer by russ about 9 years 9 months ago
If you've recently purchased the Pix, then I would refer back to your supplier, they should have shipped the Pix with the most current software release pre-installed, which is now version 8, or at the very least shipped it with version 7 installed. You shouldn't be expected to purchase an upgrade license for a new product.
Correct Answer by srue about 9 years 9 months ago
you need to make sure you have the proper smartnet contract for it (software update assurance , i think) - or purchase a one time upgrade license.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_data_sheet09186a008007d05d.html
scroll to the bottom of that page.
Overall Rating: 4.7 (3 ratings)
Correct Answer
russ Tue, 08/28/2007 - 15:30
purohit_810 Tue, 08/28/2007 - 06:18
  • Silver, 250 points or more
You need both Software and Licence but to keep existing licence (Save money)...
The PIX Security appliance Version 7.0 supports two kinds of license keys.
?Existing 4-tuple license key for PIX Version 6.3 or earlier
?A new 5-tuple license key for PIX Security appliance Version 7.0 only
?When upgrading from PIX Version 6.3 to PIX Security appliance Version 7.0, the existing license key for PIX Version 6.3 is preserved and is saved in a central location on the Flash filesystem.
?When downgrading from PIX Security appliance Version 7.0 to PIX Version 6.2 or 6.3, the existing license key for the original PIX Version 6.2 or 6.3 that was saved during the upgrade procedure is retrieved and saved to the PIX Version 6.2 or 6.3 image.
?If neither a PIX Version 6.3 nor PIX Security appliance Version 7.0 license is installed, the PIX Security appliance Version 7.0 runs in the default setting, which is a Restricted license.
Prerequisites to
Several prerequisites are required before upgrading to PIX Security appliance Version 7.0, covered in the following sections:
?Minimum Hardware Requirements
?Minimum Software Requirements
?Minimum Memory Requirements
?Client PC Operating System and Browser Requirements
?Minimum Connectivity Requirements
In case any more information required regarding licence contact to cisco.
Dharmesh
