ASA5505 vlan routing with C2960
Aug 28th, 2007
Hi, I need to have vlans on my C2960 routed using an ASA.
- Do I need to using VLAN interfaces or subinterfaces?
- Does the port connecting to the 2960 need to be trunked?
Here is the config I was planning on adding on the ASA:
#### CONFIG BEGIN ####
interface vlan 100
nameif outside
security-level 0
ip address 10.0.1.254 255.255.255.0
no shutdown
interface vlan 101
nameif mgmt
security-level 100
ip address 10.1.1.254 255.255.255.0
no shutdown
interface vlan 102
nameif ClassII
security-level 50
ip address 10.2.1.254 255.255.255.0
no shutdown
interface vlan 103
nameif ClassIII
security-level 50
ip address 10.3.1.254 255.255.255.0
no shutdown
interface vlan 104
nameif Acronis
security-level 50
ip address 10.4.1.254 255.255.255.0
no shutdown
interface vlan 105
nameif PreProd
security-level 50
ip address 10.5.1.254 255.255.255.0
no shutdown
interface ethernet 0/0
switchport access vlan 100
ip addr 70.X.X.X 255.255.X.X
no shutdown
interface ethernet 0/1
switchport mode trunk
switchport trunk allowed vlan 101-105
no shutdown
same-security-traffic permit inter-interface
#### CONFIG END ####
Also, if using same-security-traffic, can I still use access-lists to filter traffic between the vlans?
Thanks for the help.
Overall Rating: 5 (1 ratings)
