LMS 2.5.1 to LMS 3.0 upgrade
Aug 28th, 2007
I am making preparations to upgrade to LMS 3.0 but I'm going to go with the Remote upgrade option, my questions is and I hope I explain this right. The RME database on my current CiscoWorks server is about 160 gigs total and I'm thinking if I run that NMSROOT\bin\perl dir1\wrapper.pl BKP this back-up will be extremely long. One thing I was wondering is it possible to backup just the archive configs where-ever they are located on the server onto the new Server?
Or is the back-up option that is in the LMS data migration quide for LMS 3.0 is an all or nothing option?
David Stanford Tue, 08/28/2007 - 06:30
  • Cisco Employee,
The backup is all or nothing. There's no way to select certain config archives to bring over in the backup. There are so many pieces that are tied together in the file system and database.
dionjiles Tue, 08/28/2007 - 07:09
Thanks for the response. I think I may just go with a clean install instead, it would be very time consuming to try to back up that amount of data and bring it down to the new Server. Any Suggestions?
