Mohamed Sobair Tue, 08/28/2007 - 07:10
The (IP Default-Network) command is very rarly used, I havent seen yet some one using this currently.
1st: it requires IP routing to be enabled.
2nd: when uses this command within RIP domain it creates a RIP default route without using (redistribute static) command under RIP protocol.
3rd: it does add another static-route for the major Network of the Next-hop address, which in most of the cases makes some problems.
4th: ( ISIS - OSPF ) protocols doesn't recognize this command.
5th: It does require (IP Routing) to be enabled.
Summary:
Its with no doubt using a Static-default route is common & always used, comparing with the command (IP default-network).
Mohamed Sobair
Edison Ortiz Tue, 08/28/2007 - 07:42
ip default-network is just another option for a gateway of last-resort. I would compare it with an ip route 0.0.0.0 0.0.0.0 gateway.
ip classless is a different animal. That command allows the software to forward packets that are destined for unrecognized subnets of directly connected networks.
If you want to remove more about ip default-network, please check out this link:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hirp_r/rte_pih.htm#wp1122621
