Need IOS that supports VLANs for a 2801 router
Aug 28th, 2007
Can some one tell me why I can't configure an Interface Vlan on my 2801 router. I believe I have the latest ios version "c2801-spservicesk9-mz.124-16.bin". Please let me know what I am doing wrong?
islam.irshaid Tue, 08/28/2007 - 06:53
i think you mean SVI ,if you don't have layer 2 WIC you cann't use interface vlan - because the router is layer 3 not 2
shirwaziri1_2 Tue, 08/28/2007 - 06:58
the only ports that I see are:
fe0/0
fe0/1
fe0
I don't see any WIC cards. The bays are not used at all.
ankbhasi Tue, 08/28/2007 - 07:00
Hi Friend,
You will not be able to configure interface vlan on routers as it is not a layer 3 switch. For vlan routing you have to configure subinterfaces on router and configure subinterfaces with encapsulation dot1q commans to understand vlan tagging.
So configure subinterfaces
interface fa0/0.1
ip address
encapsulation dot1q
Ankur
*Pls rate all helpfull post
