Tomcat Internal Error
Aug 28th, 2007
Hi all,
Every time i select RME -> Report Generator -> Inventory - Hardware Report,
then I export this report in pdf format the following error is generated:
HTTP Status 500 - Internal Server Error
type Exception report
message Internal Server Error
description: The server encountered an internal error (Internal Server Error)
that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: Servlet execution threw an exception
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:193)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:256)
at org.apache.ajp.tomcat4.Ajp13Processor.run(Ajp13Processor.java:576)
at java.lang.Thread.run(Thread.java:534)
root cause
java.lang.OutOfMemoryError
Thanks in advance.
Filomena,
a co-worker of Leonardo
Overall Rating: 2 (1 ratings)
Joe Clarke Tue, 08/28/2007 - 09:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Looks like Tomcat ran out of memory. Restart dmgtd, and see if this problem is reliably reproducible.
marshajr Tue, 08/28/2007 - 19:34
We are also seeing this error at random intervals, running RME4.0.5 under Windows with 6Gig of memory. Restarting dmgtd only provides a temporary fix.
Joe Clarke Tue, 08/28/2007 - 20:09
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
If you can more or less reliably reproduce the problem, you should open a TAC service request so additional debugging can be performed.
Leonardo Roberto Wed, 08/29/2007 - 03:35
I executed following command lines:
dmgtd stop
/opt/CSCOpx/itp/jakarta-tomcat-4.1.12/bin/shutdown.sh
I changed parameters into catalina.sh
from #JAVA_OPTS="$JAVA_OPTS -Xmx1024m -Xminf0.1 -Xmaxf0.1 -XX:MaxPermSize=256m -XX:PermSize=256m"
to JAVA_OPTS="$JAVA_OPTS -Xms1024m -Xmx2048m -Xminf0.1 -Xmaxf0.1 -XX:MaxPermSize=256m -XX:PermSize=256m"
/opt/CSCOpx/itp/jakarta-tomcat-4.1.12/bin/startup.sh
dmgtd start
but the problem already exists;
then, I changed parameters into catalina.sh
from #JAVA_OPTS="$JAVA_OPTS -Xms1024m -Xmx2048m -Xminf0.1 -Xmaxf0.1 -XX:MaxPermSize=256m -XX:PermSize=256m"
to JAVA_OPTS="$JAVA_OPTS -Xms1024m -Xmx4098m -Xminf0.1 -Xmaxf0.1 -XX:MaxPermSize=256m -XX:PermSize=256m"
but now tomcat doesn't work!
Thank,
Filomena
Joe Clarke Wed, 08/29/2007 - 08:15
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Why did you do that at all? Modifying the Tomcat start up parameters was not recommended to you.
You cannot set the maximum memory for a 32-bit Java process to 2048 or above. The highest you can make it is usually around 1900. In this case, I wouldn't go above 1800.
As I said in a previous post, if this can be reliably reproduced, I would open a TAC service request so additional troubleshooting and profiling can be performed.
