Syslog Facility for front-end loopback test failures?
Aug 28th, 2007
Is there a way to associate a syslog facility, severity, and mnemonic for front-end loopback test failures? The following message is generated upon trying to reset the port however it doesn't have any syslog facility associated to it:
Aug 28 12:50:12.023: Fa0/41 can't be brought up because it failed POST in loopback test
purohit_810 Tue, 08/28/2007 - 09:49
  • Silver, 250 points or more
Hey,
That is not a Loopback interface that is your FASTETHERNET0/41 failed in test.
You can run TEST command on that interface it will pass from all are the test.
See on ther result what could be the impact?
on cisco web site.
Dharmesh Purohit
