7921 using wpa2 with EAP Fast
Answered Question
Aug 28th, 2007
I have some 7921 phones. I am trying to connect them using a 4404 wlc on firmware 4.1.181.0
I can connect using wep, but it wont authenticate using wpa2. I have tested the ssid with my laptop and it works, but with the phone it isnt even hitting the radius server.
Any suggestions?
Correct Answer by migilles about 9 years 7 months ago
Will want to use version 1.03.
Also for WPA2, will need to set the phone to either EAP-FAST or AKM mode. AKM mode will use LEAP for 802.1x. EAP-TLS and PEAP are not supported currently on the Cisco 7921G.
If using EAP-FAST, may want to increase the 802.1x timeout on the controller. See http://www.cisco.com/univercd/cc/td/doc/product/voice/c_ipphon/english/wip7921/relnote/rn7921_3.htm#wp161964.
Overall Rating: 5 (1 ratings)
burnsidestev Tue, 08/28/2007 - 10:23
also on the phone:
App Load ID CP7921G-1.0.2.LOADS
Boot Load ID BL-P203-6065E201
WLAN Driver id is 5.0.0.96
WLAN Firmware ID 4.1.0.80
Correct Answer
migilles Tue, 08/28/2007 - 23:32
  • Cisco Employee,
