NAT Access List Question
Aug 28th, 2007
Some of the examples I have seen of an access lists for NAT inside local addresses start with the first host in the range such as:
access-list 1 permit
I would think that the correct syntax would be the network address, not the host address, like this:
access-list permit
Am I wrong or right, or are both permissible?
mohammedmahmoud Tue, 08/28/2007 - 12:46
You are right, and any way if you enter "access-list 1 permit" the router will automatically convert it to "access-list 1 permit", as the wildcard mask is telling the router which bits to match and which to ignore and the route will accommodate according to it.
Mohammed Mahmoud.
mohammedmahmoud Tue, 08/28/2007 - 12:56
Hi Oren,
For exams i'll say go for the standards by the book and use the "access-list 1 permit".
I hope that i've been informative.
Mohammed Mahmoud.
