Difference between Zone Set and VSAN
Aug 28th, 2007
It looks from the config the a Zone is the connection between the server and the switch port, is this correct?
What is the difference between a Zone Set and a VSAN?
Overall Rating: 5 (1 ratings)
inch Tue, 08/28/2007 - 15:16
A zone can contain "connections" from server, port on switch, storage device or another server.
A zoneset is a collection of zones. One zoneset can be active in a vsan at a time.
A vsan (virtual san) is a means of segregating traffic from one SAN. You might want to do this to separate development traffic from production.
inch Fri, 04/11/2008 - 21:51
One reason to have multiple zonesets is for a backout procedure after making a change.
It is possible to clone your active zoneset to a new zoneset, make your changes then activate this new one.
If something went wrong you can simply re-activate the old zoneset.
spwvol1978 Wed, 08/29/2007 - 19:28
vsan: an allocation of switch ports that can span multiple physical switches and forms a virtual switch (i.e. fabric). A single switch can contain multiple vsans.
zoneset: a set of zones. You zone a fabric and activate a zoneset against a fabric. Only 1 zoneset can be active in a fabric.
Trending Topics: Storage Networking
