Cisco 837 - stile_check_flow_entry_change : no subblock
Aug 28th, 2007
I'm getting the following error in the logs on my 837 router. I've done a search on the site and also Googled it but nothing has come up.
Has anyone come across this before and if so what is causing it?
The router has also recently started dropping it's dsl connection to the ISP. A shut/no shut of the interface doesn't correct the problem but a reload does.
I'm also wondering if the two are connected or is it just coincidence and I just noticed the error message because I was looking in to the ISP dropping.
The IOS is version 12.3(11)T3,
Thanks for any help
