Dot1q Tunnel on 4506
Aug 28th, 2007
I recently upgraded my 4506 to IOS image:cat4000-i9s-mz.122-20.EW4.bin
However, after doing so I am unable to configure interfaces for dot1q-tunnels. I am able to set the global command, but the interface subcommands don't list dot1q-tunnel as a mode option.
I don't see a bug for this and the command sets on show the command should be "switchport mode dot1q-tunnel"
Anyone seen this before, or know what I am missing?
johnsonk1024 Tue, 08/28/2007 - 16:15
I think I may have found my problem. Does anyone know if the WS-X4148-RJ supports dot1q tunneling on the interfaces?
JORGE RODRIGUEZ Tue, 08/28/2007 - 16:57
Hi, what sup engine type do you have?
based on these two doc this feature is only supported on supV for 4500 series platform.
See Layer 2 features
otherwise go to software advisory and seach for dot1q-tunneling or L2pt tunneling features based on your hardware to get right ios.
