how to check a ifindex of the interface in router
Aug 28th, 2007
Dear All,
i am looking for a command which can tell me all the ifindex assigned to interface in router. i know that there is one command in catos show ifindex but i couldn't find the similar command in router.
please help.
thanks
Overall Rating: 5 (2 ratings)
jreekers Wed, 08/29/2007 - 08:20
Hi.
show ifindex and show port ifindex only exists on CAT code.
For CAT 6k running IOS (native IOS), there is no command for this info. So if you want to check what snmp index is associated with what port/interface, you can do this as you would do on any router (IOS):
You need to poll ifName and ifIndex from a host machine and then correlate the two output to see what snmp index is assigned to what port. It's easiest to do from a UNIX server, but if you load any of the freeware polling software on to a PC you can also do it. Here's an example of the poll, and what to look for:
% snmpwalk -c public 172.16.100.30 ifName
IF-MIB::ifName.1 = STRING: Gi1/1
IF-MIB::ifName.2 = STRING: Gi1/2
IF-MIB::ifName.3 = STRING: Gi5/1
IF-MIB::ifName.4 = STRING: Gi5/2
IF-MIB::ifName.5 = STRING: Gi5/3
IF-MIB::ifName.6 = STRING: Gi5/4
IF-MIB::ifName.7 = STRING: Gi5/5
IF-MIB::ifName.8 = STRING: Gi5/6
IF-MIB::ifName.9 = STRING: Gi5/7
% snmpwalk -c public 172.16.100.30 ifIndex
IF-MIB::ifIndex.1 = INTEGER: 1
IF-MIB::ifIndex.2 = INTEGER: 2
IF-MIB::ifIndex.3 = INTEGER: 3
IF-MIB::ifIndex.4 = INTEGER: 4
IF-MIB::ifIndex.5 = INTEGER: 5
IF-MIB::ifIndex.6 = INTEGER: 6
IF-MIB::ifIndex.7 = INTEGER: 7
IF-MIB::ifIndex.8 = INTEGER: 8
IF-MIB::ifIndex.9 = INTEGER: 9
From the above 2 outputs, Gi5/7 is snmp index 9.
ifName is Oid .1.3.6.1.2.1.31.1.1.1.1 and ifIndex is oid .1.3.6.1.2.1.2.2.1.1
Hope this helps.
-J
axfalk Wed, 09/10/2014 - 06:07
is there a similar command for n5k?
Thanks.
-Greg
Don Muthukumarana Thu, 01/08/2015 - 05:30
In IOS XR, show snmp interface
ifName : TenGigE0/3/0/0        ifIndex : 1581
ifName : TenGigE0/3/0/1        ifIndex : 1582
ifName : TenGigE0/3/0/2        ifIndex : 1583
ifName : TenGigE0/3/0/3        ifIndex : 1584
ifName : TenGigE0/3/1/0        ifIndex : 1579
ifName : TenGigE0/3/1/1        ifIndex : 1580
ifName : Bundle-Ether100       ifIndex : 11105
ifName : Bundle-Ether101       ifIndex : 11106
