EasyVPN with a ASA 5505
Aug 28th, 2007
The aim is to deploy 2 ASA 5505 and to create a VPN between them.
I saw ASA can operate as both client or server for EasyVPN.
On the VPN interface (ASDM) I find the check button to activate the EasyVPN option but it seems to be for the client side only.
How can I configure the server side on my main site? Can I link two distinct agencies to the the main site py EasyVPN ?
Is there a link or URL for documentation or HOWTO ?
Edit: for debug, how can I permit the Ping command to go throught my ASA 5505 ?
Thanks for your answers.
JORGE RODRIGUEZ Wed, 08/29/2007 - 11:38
  • Green, 3000 points or more
Hi Lionel,
first make sure both appliences have proper license for site-to-site vpn, known as VPN-3DES-AES or 3DES-AES, usually seen in "show version" as being enabled.
Here is an example for site to site vpn tunnel between two security appliences.
http://www.cisco.com/en/US/partner/docs/security/asa/asa72/getting_started/asa5500/quick/guide/sitvpn_b.html
as far as allowing ping say from site a to site b internal hosts through that tunnel.
add in asa
"management-access inside"
Jorge
